Zpeedster M
I hope your R sales transaction is completed fastidiously so this thread can finally die a dishonorable death & all your myth buster's conspiracy theories cease
I guess you donāt believe the data from Blackstoneā¦. Or engine oil experts like specialist Lake Speed Junior that say always follow the data from your engine oil results, not what the marketing brochures and hearsay say. Thatās just noise.
I knew engine oil discussions were like a religion, but didnāt think showing raw data would generate such a toxic reaction to data analysis. The first part of that AI data analysis was from raw data.
I think youāve just motivated me to keep the car, and keep collecting data and showing results.
Looks like you need a few more vaccine shots.
where do you find the specs of the Honda Ultimate 0w-20?Actually I did speak to Blackstone in detail and waited for hours on 2 different calls, 2 different people while they went through the data.
They could not share the data, but they ( Once it was a guy and the second time a female ) said "look John I'm looking through many type R's right now on my screen, and we are not seeing any improvement from all the K20C1 engine oil analysis with 5w30 Motul 300V. It looks the same, no better. We're not seeing any differences."
I've also spent 2 hours at least on call with Motul, and French sales rep was convincing me after 2 - 1 hours calls - that I needed to go to 0w-20 Motul 300v - and 5w-30 built engines - of course the most expensive solution, and I could run it for 3500 miles and 2-3 track days, which is bullshit. I have the data from people running it - It degrades way faster than a API SP engine oil. Call them, find out yourself. Or look at Motul 300V oil analysis, vs API SP over 3500 miles.
If you look at the specs on that, it's thinner than the Honda Oil or even Penzzoil Ultra Platinum....
I'm just relaying fellas the truth of what I'm finding..
If I blow my engine, and the data from blackstone is all bullshit, and the marketing brochures and sales guys are the real truth.
I'll be the first to admit I was wrong.
Look below.. That' Motul 300V 7.8mm2/s CST at 100C, and Pennzoil Ultra Platinum is at 8.8!
That's way thinner than the Honda oil and Pennzoil 0w-20. According to Motul, that's good for 3500 miles and 2-3 track days, and degrades faster than API SP??? You tell me - how crazy is that?
So the only info they could talk about is Motul, not Amsoil or the any brands? I find that very odd. I still doubt you would see any significant improvement over using one or the other because all of them are fine, at worst youd see a marginal difference.Actually I did speak to Blackstone in detail and waited for hours on 2 different calls, 2 different people while they went through the data.
Its good to have these indepth discussions so we can all learn and potentially benefit by having that bit of extra protection, which was going on before you hijacked the thread with nonsense and wild claims. I certainly learned from the discussions early on in the threadOk Fellas, I've finally created a new Thread for only Oil Analysis. Please post there those of you that have have personal engine oil lab results - data analysis only. No comments. Thank you
https://www.civicxi.com/forum/threads/-engine-oil-red-pill-thread-only-post-if-you-have-uoa-official-honda-civic-type-r-k20c1-engine-oil-analysis.57366/
I do respect everyone's ideas, and freedom to think. It's good to have a heated topic. But it's also good to have a separate scientific approach to testing these beliefs.
Take care,
Adios
John
Dude you are insane, and honestly have no idea what you are even talking about. You are just spouting nonsense, and at this point trolling or just being argumentative because you have an ego.You make no senseā¦. I only have personal data I shared with Honda oil, and weāve looked at data on 300v given to all of us. Itās all about data, what oils are proven to work well on this engine. Which produce the most optimal results. You can clearly see power losses and friction increase by motul dyno testing. I think the issue is somehow me providing data or motul oil engine samples data, and motul itself testing the the stock engine with its oils and loosing power and saying itās due to frictionā¦.
I understand at some point people donāt wanna believe the data because it goes against most everything youāve heard online.. itās a tough pill to swallow I get it. Iām not saying Honda is the best engine oil. I am saying only what the data is showing me that it protects the engine in an excellent way and Iām telling you what Motul is telling us, that you loose power and friction is increased.
if you donāt wanna believe real Dyno tests and real Blackstone tests, I donāt know what to say. thatās all I got.
if youāve got more oil engine samples data then post it to the other thread.
I dont think the thread should be locked. The other guy should just be banned or at least blocked here since he is just trolling.You post the motul video where they say if you track the car you should probably use a heavier oil.
we should really lock this thread, use whatever oil you want and we will use whatever oil we want. Just stop using words like "in conclusion" and doing the virtue signaling crap you keep doing.
toodles
Nothing wrong with using Honda Ultimate for street use. From the reports its clear that it thins out from track abuse. This isn't surprising since its 0W20 oil, its not supposed to be thick.I called Blackstone and talked to them about the Mobil 1 0W20 and Honda Ultimate 0W20. They said majority of the oil samples they get in are with the Honda Ultimate 0W20 and Amsoil (didn't specify which weight with the Amsoil). Based on his readings, the Honda Ultimate did have more additives compared to the Mobil 1, but its not a significant difference to say one is better than the other. I plan on changing my oil every 3000 miles or so and they said running Honda Ultimate is a great choice and 0W20 shouldn't be a problem based on my driving style. I personally have ran Amsoil in all my cars including my current M5, but I'm going to stick to the Honda Ultimate 0W20 on my CTR and if the engine ever decides to blow then so be it.... I will just get a Spoon drop in crate motor and run whatever oil Spoon recommends with their engine
My engine is bone stock aside from a Spoon drop in air filter which I plan on going back to the stock air filter soon. I only have the desire to slightly modify the suspension on the CTR.
Interesting. I always thought having more additives is better. I still been on the fence on using M1 over the Ultimate. I asked them to check for fuel dilution on my M5 oil sample and they reported back saying the flashpoint was high which rules out fuel dilution.Nothing wrong with using Honda Ultimate for street use. From the reports its clear that it thins out from track abuse. This isn't surprising since its 0W20 oil, its not supposed to be thick.
You should call another UOA Lab. Blackstone doesn't test for fuel dilution and Im curious what the numbers are with the historic data. I have tomorrow off I think so I can hit them up and see.
Some people recommend the Mobil-1 ESP because the additives are alot lower. High Ca and Mg are not good long term for DI turbocharged cars because it increases blow by and carbon buildup. Just something to know but you'll be fine regardless.
Its better because it extends the service interval. Dont really know about the chemistry or logic behind it yet but the consensus is that its not good really good for modern turbo GDI engines because it increases fuel dilution. It probably incresses it beyond the acceptable 2% range. GDI and turbo engines are sensitive to fuel dilution already.Interesting. I always thought having more additives is better. I still been on the fence on using M1 over the Ultimate. I asked them to check for fuel dilution on my M5 oil sample and they reported back saying the flashpoint was high which rules out fuel dilution.
agreed. When the guy is using āred-pillingā terms unironically you know itās a lost causeDude you are insane, and honestly have no idea what you are even talking about. You are just spouting nonsense, and at this point trolling or just being argumentative because you have an ego.
