2025 Si full digital cluster works in 22-24 and here's what you need to get it done!
ayospoonay
Josh
Orlando
2022 PWP Si
I would recommend you buying the parts from the dealer you are having them installed at. Most dealers won’t install parts you don’t buy from them.
Johaw
2023 Civic si
Agreed i made this mistake luckily i dont mind installing it myself but i still have to have them program it and having them do the full process wouldve been much easier on a side note mine arrives wednesday so next weekend ill be joining the crew
Mossy117
Brandon
New York
22 Civic Si
I ordered the parts last Sunday and still no order update.. stuck saying In Progress
Shankmeyster
Shankmeyster
AZ
23 Si
Well the cluster is now on backorder so might wanna contact whoever you ordered from.
Mossy117
Brandon
New York
22 Civic Si
Got good news, I called and they’re waiting on one of the switches to come in. They already have the cluster and harness! Should arrive next week
Johaw
2023 Civic si
My parts arrive today! Going to start taking the car apart friday afterwork and hopefully get everything sorted on saturday
Shankmeyster
Shankmeyster
AZ
23 Si
Let's see who's gonna be #3
si2022
Maryland
2022 Civic Si
Is the dealer only needed to reset the mileage counter, or do they need to do something in order for the new cluster to work?
Shankmeyster
Shankmeyster
AZ
23 Si
They have to transfer the info from the old cluster to the new one and that's all you really need them to do. If you can get them to pull the old one and bolt up the new one then that's even better to not have any issues.
Like I said earlier, if you want to pull the dash apart to the point where your old cluster just needs to be unbolted and the new one bolted in then that will save you a lot of money. Regardless, you will also have to swap out the buttons and harness inside the steering wheel.
si2022
Maryland
2022 Civic Si
What are they transferring? Is it anything more than the mileage? If I don't care if the mileage is off do I still need the dealer?
Shankmeyster
Shankmeyster
AZ
23 Si
So you want to have a car with a mileage discrepancy? I don't know what else needs to happen with them programming the cluster. Once you plug it in, if it works without having the info programmed by the dealer, you can never reprogram it just so you know.
ayospoonay
Josh
Orlando
2022 PWP Si
Gonna see some marketplace post... "2022 Civic Si only 30 miles for sale 50k!"
si2022
Maryland
2022 Civic Si
I was just thinking of having the dealer reprogram or adjust the mileage after I install it myself, but it sounds like that wouldn't work.
Perhaps I can just pull the old one and bring the part to the dealer together with the new part and have them transfer it like that.
From your earlier post (https://www.civicxi.com/forum/threa...hat-you-need-to-get-it-done.54726/post-908110) it looks likey they're are some new settings on the touchscreen, which is probably a separate update as well.
ayospoonay
Josh
Orlando
2022 PWP Si
That will not work. Cluster has to be new to be reprogrammed.
