27WON FL5 Exhaust System
nvtive_b
Love 27won, but God the price is insane for something heavier than stock
I mean, it's $2k and includes the front pipe. You're not finding a quality exhaust for under $2k that I've seen. Where did you see the weight of this exhaust?
Believe it was earlier in this thread where someone mentioned it was heavier and 27won confirmed
Well, I'm not surprised as I'm sure most stainless steel exhausts are.
Yeah, the (teaser) sound, design and materials are top notch as always, but you usually see 27won put a lot of effort into weight reduction too. Looking back, @Tougefl5 mentioned that Vlad has said it was 70lbs.
This is an accurate statement, but not 20+ lbs. over stock. Doubtful there's an exhaust on offer that weighs that much.
Robo7
Robo7
Vlad stated the weight in the other thread for the exhaust. 70 lbs is for the catback that doesn't have the resonator. The turbo back with the resonator would be slightly heavier. Stock exhaust is around 50 lbs if I recall correctly.
About ~70 lbs for the lightest catback version (non-res) so not something I'd call a weight savings mod 😂 . Primarily a function of using 80MM (3.125 inch) piping through the majority of the system and the mufflers in the axleback to keep drone at bay
Evox787
Elvin
2024 civic type R , Evo X 2010, Scion XA 2006
95% sure it was $2,694 for turbo back and $2,094 for cat-back.
The catback is the one that comes after the mid pipe or whatever is the name of the one under the engine 😂! Because that’s what I’m looking for nothing too loud but loud enough 😂.
