2025 Si full digital cluster works in 22-24 and here's what you need to get it done!
Johaw
2023 Civic si
I work for the company so I got a deal. It was around 3 hours of labor so you'd have to check what the labor rate is where you go. If you know how to take the stuff apart yourself, just leave the cluster in there with everything else already taken out/replaced, and have them do the program and install to save as much as possible. Every store is going to be different. I have also been taking my Honda's to this store for around 20 years.
Did you flash your car or stock when you brought it in? I seen youre tuned i havent brought my car to the dealer since being tuned.
Websitesdown
My dealership doesn't care if that helps. They know me too though.
Zero Cool
Dallas, TX
2024 Civic Si
Yessss! Thanks for getting this solved for all of us! This was on my list of mods to eventually do, thank you for taking all of the guess work out!
Johaw
2023 Civic si
I wish i knew someone at the dealership lmao but ill just leave it be i dont plan on having much of anything done at the dealer aside from this
Shankmeyster
Shankmeyster
AZ
23 Si
Yes, I almost always flash to stock before going to the dealer. Don't want to have any issues with the programming.
Johaw
2023 Civic si
After contacting my 2 closest honda dealerships they do not do the install but will program if i install myself :’)
Shankmeyster
Shankmeyster
AZ
23 Si
That's fucked! Well, better bring your tools I guess. Luckily it's not that hard to swap them out once you have the OEM cluster ready to pull out. Hope you know how to pull the steering wheel apart to replace the harness and button clusters. I don't know why a Honda store wouldn't swap out a cluster. What if yours was broken?
Johaw
2023 Civic si
That's fucked! Well, better bring your tools I guess. Luckily it's not that hard to swap them out once you have the OEM cluster ready to pull out. Hope you know how to pull the steering wheel apart so replace the harness and button clusters. I don't know why a Honda store wouldn't swap out a cluster. What if yours was broken?
one of them doesn't install it because its not direct replacement the other said they'd only do it if i bought the parts through them although they are factory sealed parts. it has to be through that dealership i get the parts.
I didnt think they'd do that as i work for the parts/service department at a service center for another company and we have customers that bring their own parts and we do the work.
$200/hr labor rates are another thing to top it off id almost prefer to do majority of the install myself if only i could program it lmao
I assume i can find enough different videos of people doing things with surrounding parts to get it all done myself aside from the program.
Shankmeyster
Shankmeyster
AZ
23 Si
$200 an hour is INSANE! That's supercar repair shop rates.
Johaw
2023 Civic si
The service center i work at sells/services vehicles that are well over a million for some with the cheapest being like 300k and thats higher than our labor rate its ridiculous
Shankmeyster
Shankmeyster
AZ
23 Si
The only part you need to have Honda do is program the cluster for the swap, but you'd literally have to swap the cluster out in the service drive or dealer lot in order to not have a mileage discrepancy. I don't understand why they wouldn't be able to just pull out the old cluster and put the new one in and bolt it up if you already had everything ready to be unplugged/unbolted.
Basically get it to this point and then have them program and pull the old one and put the new one in it's place and you will put everything back together yourself.
11th Gen Honda Civic 2025 Si full digital cluster works in 22-24 and here's what you need to get it done! 1727195194832-x6
Savannah@TSP
www.twostepperformance.com
'23 Si, '98 EJ6, ‘20 FC4 (sold)
Stop making me spend more money.
Great work. Looking forward to the install (eventually).
