Knock, knock, Who's there? Detonation!!! Massive timing pullGiven the octane discussion, and the Honda news page that says premium is preferred, I wonder what that curve looks like with 87![]()
Do you think that'll really happen with a compression ratio of 9.8:1? Honda's official manual does say regular is okKnock, knock, Who's there? Detonation!!! Massive timing pull
I vaguely remember some discussion around the fact that our octane measurements are different, so your 98 is like our 91 or somethingIn Australia we have 98 octane...Shell V-Power and others.
So basically that "torque dip" your seeing which I wouldn't call a dip at all is a result of the wastegate trying to gain boost control. It's nothing to be concerned about and you can't fix it with octane. It'll pretty much always happen but you will never feel it in the car. It's based on what gear your in and the load on the turbo. You can try to tune it out so it's perfectly flat but again, not a issue. Once the wastegate has control it smooths out.Wait so w/ 93 octane there'd be no torque dip?
J/K (maybe)
Correct 98 in Australia is 91 in the US, its the way octane is measured AKI VS RON.Do you think that'll really happen with a compression ratio of 9.8:1? Honda's official manual does say regular is ok
I know, I'm just being dumb while waiting for mine to be delayed to the east coast againHahaha.
Obviously you can have dips from timing changes and KR corrections on N/A motors. Just stating my opinion on whats going on on that graph.
Thanks for the clarification.Correct 98 in Australia is 91 in the US, its the way octane is measured AKI VS RON.
Lower octane will result in lower hp and less timing. Probably some knock counts as compared to 91/93 octane (US).Do you think that'll really happen with a compression ratio of 9.8:1? Honda's official manual does say regular is ok
You take out traction /tire issues when bolting to the wheel hubs.I wouldn't consider crank because you are still dealing with drive train loss.
I think dyno rollers are doing a bit of estimation to a degree. Maybe someone more knowledgeable can shed more light.
