Weirdo 2025 Type R Noob wants to INCREASE ground clearance. He clearly needs help.
FL5HondaGuy
Boston
2024 Championship White FL5
You're on H&R's, right? Wondering if you knew if 275/35/19's would work but I doubt it based on your pics.
Just because you can doesn't mean you should. 265 is plenty wide enough for this car. With the 20mm/25mm spacers and slight H&R drop it is the perfect OEM + look. If I want to pop for 5k wheels down the road then I will revisit but for now it is perfect.
