Tickle
What inspired you to buy this car?If you drive 1000 miles per month, the gas price difference can be $500 a year. Overthinking?
It doesn't seem you're genuinely interested in getting to bottom of these minor inconsistencies. It's clear you're pressed up about saving a few bucks. Just put 87 in the car and be done with it.If you drive 1000 miles per month, the gas price difference can be $500 a year. Overthinking?
You are not spending an extra $500 a year.If you drive 1000 miles per month, the gas price difference can be $500 a year. Overthinking?
Usually ECU will pull timing if it senses knock, this is a bigger issue for turbocharged engines. There's a variety of reasons why this is important, some being used error, gas truck filling the reservoir with the wrong gas, old gas, crappy gas, etc. sometimes you find yourself stuck in the middle of nowhere and they only have 87.They make it clear that premium is recommended. 87 is listed as a minimum. As others have pointed out, this indicates that you can get away with 87 if you have to, but you should use 91 given the option. Honda would not recommend premium if 87 was equally serviceable.
Looking at tuning threads, it's clear these ECUs are very aggressive. They do not learn over time; they react and reset (I believe every time you press the pedal).
87 comes with risk, and again, given the $500 / year potential delta you provided compared to the cost of the car... it doesn't seem to be a risk worth taking.
We just had a similar thread on the DE5 forums -- keep in mind the DE5 tune is even more aggressive and 93 is recommended -- and I cannot understand spending $50k+ on a car if an extra $500 / year in fuel savings is worth risking the condition of that vehicle to you...
What are the errors about wheel lug nuts?FL5 has a lot of documentation errors, like wheel lug nuts.
It’s still showing 80 in my manual, I used that number to check my wheels yesterday, and found out no wheel lock key coming with the car. I also checked tire pressure, all 53. I believe the dealership did nothing for pre-delivery inspection.@xpeng
In US owners manuals it says the lug nuts should be torqued to 80 ft lbs. This is the correct spec for all Civics except the Type R. The Type R uses larger lugs which should be torqued to 94 ft lbs. Hopefully they’ve fixed this info in all manuals by now, but I don’t know. https://www.civicxi.com/forum/threads/lug-nut-torque-for-fl5-owners-manual-wrong.51756/
That’s annoying. They should’ve given you a key if you got wheel locks. Are you sure they didn’t put the key in the “spare tire” compartment, maybe? This is another topic, but most wheel locks are pointless. There are a couple of brands of locks that are actually effective. Common wheel locks are hardly a deterrent unfortunately.It’s still showing 80 in my manual, I used that number to check my wheels yesterday, and found out no wheel lock key coming with the car. I also checked tire pressure, all 53. I believe the dealership did nothing for pre-delivery inspection.
My ITS had overinflated tires too and didn't had a long journey like the CTR.That’s annoying. They should’ve given you a key if you got wheel locks. Are you sure they didn’t put the key in the “spare tire” compartment, maybe? This is another topic, but most wheel locks are pointless. There are a couple of brands of locks that are actually effective. Common wheel locks are hardly a deterrent unfortunately.
Over-inflated tires is a common “problem” too. This is done from the factory because they’re on a long journey from Japan and no one will monitor the tires until the dealer gets the car. The dealer may opt to keep the tires over-inflated basically because the car could sit in the showroom for months and rarely move. Over-inflating helps prevent flat spots. They should have checked this before you drove off the lot.
Going to stop here as to not hijack this thread any further.
The car is tuned to work 1st with premium fuel and adjust if knock is detected.Usually ECU will pull timing if it senses knock, this is a bigger issue for turbocharged engines. There's a variety of reasons why this is important, some being used error, gas truck filling the reservoir with the wrong gas, old gas, crappy gas, etc. sometimes you find yourself stuck in the middle of nowhere and they only have 87.
