Quality of Life mods for the FL5
On my previous sport hatch I was a bit of a mod-maniac, but with the type R I want to only do mods that will help with stuff like maintenance. Right now I'm considering some pinch weld pucks to prevent damage (my last car had them get all creased up), a mesh for the side vents to prevent rocks, and maybe a cooling plate since there's nothing bad about reducing temperatures.
Any other suggestions?
Mid-Atlantic Region
Pela 650 Oil Extractor makes oil changes quick, clean and easy. I’ve been using mine for over 20 years where it has saved me a lot of time and money.
I've seen a couple people on the forum run RokBlokz splash/mud guards on their FL5 and it includes the mesh rock guard. I use their 11th Gen splash guards on my Sport Touring. I like theirs better since the guards seem a bit more sturdy and aren't flimsy like others.
https://rokblokz.com/collections/ho...cts/honda-civic-type-r-fl5-2023-splash-guards
menikmati
STI, BRZ, FL5
I use Fumoto valves in all my vehicles, just attach a hose or drain the oil directly into a container. Works great in my BRZ where the oil filter is top-mounted so no drain pan needed. You'll still have to use a drain pan for a bottom-mounted filter, though.
Not maintenance-related, but if you have to use a remote for your garage/gate then I would highly recommend the Homelink mirror.
@JDM_DOHC_SiR has a great thread about it here: https://www.civicxi.com/forum/threads/plug-and-play-homelink-mirror-for-fl5-1-hr-install.51749/
R20289
Derrick
Georgia -USA
2024 Honda Civic Type R
R20289
Derrick
Georgia -USA
Homelink mirror (if you want a garage door opener built in)
Badannlv skid plate. (It has doors for the oil drain plug and oil filter, so you don’t have to remove the whole plate to do an oil change)
Megachip just came out with some rock guards that look good
Verus engineering makes a good solid lift point puck that stays on car to protect the pinch weld.
I also just added a Fumoto drain valve for the drain plug. (First time using one, so still developing an opinion on it)
princers
Z
25 Type R
mugen scuff plates for the door because i have a habit of kicking the bottom of the door panel everytime i get out. lifesaver on both my fk8 and fl5, must have mod imo
Maybe I’m wrong and misunderstood, but I read somewhere that the Homelink mirror isn’t quite a 1:1 fit to the Type-R’s mirror bracket…or something along those lines? Is that true? I wanted one until I read that.
menikmati
STI, BRZ, FL5
I have not had any fitment issues. Are the fitment issues described as the window mount feeling "loose"? The only way I can think of that happening is maybe not all the brackets are mating properly to the camera when trying to twist it back into place.
The Homelink mirror is as secure as the OEM mirror in my opinion; no loose feeling or rattling.
R20289
Derrick
Georgia -USA
My Homelink mirror fits perfect. No issues
Yes! Jogging my memory, that sounds correct. Someone was complaining that the mirror fit was loose and blamed it on the parts not being an exact fit…which I thought was strange. Sounds like a case of user error.
Los Anageles
Nanook
JP
Chester, VA
I considered the Fumoto drain valve, but ended up getting the Votex drain plug, seems that less things could go wrong with it... but have not yet done my first oil changes (only about 600 miles so far)
https://votex-us.com/honda-civic-st...il-drain-valve-2002-2023-2-0-liter-4-cylinder
Never heard of these before. I just ordered 4 though. One for every car’s oil I have to change! I’ve had the Fumoto and didn’t love them. These are slick.
