Gansan
- First Name
- Glen
- Joined
- Sep 13, 2017
- Threads
- 5
- Messages
- 407
- Reaction score
- 235
- Location
- San Diego, CA
- Vehicle(s)
- 1999 NSX, 2024 Civic Type R
The difficulty is also
1. the radiator fan will cycle on and off to keep temps in line.
2. The thermostat will also adjust coolant flow to stabilize temps.
The only driving situation you can really check efficacy is on track when the cooling system is fully saturated. You need the engine to be generating enough heat to push the cooling to the limit and you also need full speed air to be flowing past the car to generate the dynamic pressures you're depending on to vent the hot air.
