Can you share the data and conclusions you were able to draw from your testing of the Eventuri intake on @PointByPatrol 's car? I recall you mentioned it was moving a lot of air. What does that mean exactly for performance, consistency, and IATs? How did it perform relative to the stock panel filter? Also, why a drop in panel filter and not one of the intake systems (Eventuri, PRL HVI, Blitz, GruppeM) on the market?
So data sadly was limited due to the unfortunate accident that @PointByPatrol had. But I saw a consistent gain of about 5g/s through the MAF sensor which means more air was coming through on every log. IAT’s were similar to stock since it draws air from the same place and there is no change to the snorkel. A place I think might be worth some R&D to develop one that picks up air better without blocking too much airflow.
For consistency I mean that the more air you get obviously more power can be made. Now speaking specifically of IAT’s that is the single biggest power killer aside from bad quality fuel. The car really kills power with high IAT’s.
The only reason I recommend the drop in filter is just because of cost. You get a bit better performance not as much as an intake. But still some gains are there for pennies on the dollar compared to the intakes. Unless you are moving some serious air with a bigger turbo the stock box won’t be a limitation.
Another factor that needs to be considered regarding IAT's and the data that I was able to provide was the steady increase in ambient temperatures as the season transitioned from winter to spring. I'd imagine an extra 5g/s would take a little bit longer to heat since the volume of air charge had increased. Ultimately the biggest limiting factor will be the turbo once everything gets hot due to it's size.
Actually the more air that is compressed the more heat it will produce. But still I found them to be consistent. I still have to get more data to put up actual data for you guys.
egxflash
CA
2024 Integra Type-S
Anybody in here get this already?
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
We have some in stock if interested. Haven't had anyone send us or upload any clips yet.
-Josh
realtorhoff
South Florida
2024 SGP FL5
Anyone install this yet?!
egxflash
CA
2024 Integra Type-S
Somewhat adjacent but my DE5 is with Borla right now as they are fitting the Atak exhaust to it (based off the FL5 version).
I'll be sure to offer insights on the ITS forum and here if that's welcome.
realtorhoff
South Florida
2024 SGP FL5
Absolutely! That would be greatly appreciated. Keep us posted!
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
