Savannah@TSP
www.twostepperformance.com
'23 Si, '98 EJ6, ‘20 FC4 (sold)
One of our passions at TSP is taking a stock, turbocharged car and adding a little...✨spice✨.
We've applied this to many of our builds, and are applying it to our 2023 Civic Si as well.
Fun fact: our Si was the tester car during Stage One+ and Stage 2's development. It’s also playing a large role into upcoming tunes. ;)
Check out the progress so far!
11th Gen Honda Civic TSP FE1: a spicy Si tspfe1_900x
11th Gen Honda Civic TSP FE1: a spicy Si 1_8b5dd462-4115-4776-bcfd-9edc582608ff
Instagram: @tsp_savannah
Built L15CA Longblock
TSP L15 Head Stud Kit
Boundary Oil Pump Gears
Wunderladen x TSP Oil Pan Baffle
Wunderladen Rear Camshaft Plate
Hondata Denso Fuel System Upgrade
Spoon Magnetic Oil Drain Bolt
JE Pistons 73.5 / 10.3:1
Saenz Performance S-Series Rods
Wunderladen Timing Cover Plate
Wunderladen 75A Rear Motor Mount
Skunk2 Ultra Valve Springs, Base, and Retainer Kit
Bolt Ons
PRL High Volume Intake (Standard Bore)
PRL HVI Cold Air Intake Duct
27WON Air Intake Snorkel
PRL Turbo Inlet Pipe
PRL Front Mount Intercooler
PRL Charge Pipe Upgrade
PRL High Volume Intercooler Outlet
27WON Gin BB Turbo Upgrade
TSP High Efficiency Downpipe
PRL Motorsports Front Pipe
Thermal R&D Frontpipe-Back Exhaust
CSF Aluminum Radiator & 1.4b Cap
Acuity Reverse Flow Radiator Hoses
Wunderladen Racing Oil Catch Can (PCV)
Tuning
KTuner V2
Custom Flex Fuel Tune by DRob @ IMW
27WON Honda 4 Bar MAP Sensors
PRL Flex Fuel Kit
Dress Up
PRL Billet Oil Cap - Black
TSP Titanium Inlet Pipe Stud Kit
TSP Titanium Exhaust Stud Kit
TSP Cerakoted Valve Cover
PRL Coolant Overflow Reservoir Tank
Spoon Antiglare Wide Mirror Set
11th Gen Honda Civic TSP FE1: a spicy Si DSC05443_1_1024x1024
Drivetrain
RV6 FK8 Retro Flywheel + Stage 0 Clutch Kit
Hybrid Racing Short Throw Shifter
Hybrid Racing Competition Shift Rod (Spring/Fall/Track)
Hybrid Racing Alcantara Shift Boot
Hybrid Racing Chicane Delrin Shift Knob
Hybrid Racing Shifter Cable Bushings
Hybrid Racing Heavy Duty Detent Springs
Brakes
27WON Big Brake Kit
Wunderladen Rear Caliper Bushings
TSP Rear Brake Upgrade Kit
MOTUL DOT4 Brake Fluid
Wheels
Konig Hexaform (Gloss White) 18x8.5 +43
Muteki SR48 M12 x 1.5 Lug Nuts (Black)
Michelin Pilot Sport 4S 255/35/ZR18
Suspension
Silver's NeoMax Coilovers & Endlinks w/ Swift Spring Upgrade (10k)
27WON Front Strut Tower Bar w/ Brake Brace
RV6 Adjustable Rear Lower B Arm
RV6 Adjustable Rear Lower A Arm
RV6 Adjustable Rear Sway Bar & Billet Endlinks
RV6 Front Compliance Mount
RV6 Rear Knuckle Spherical Bearings
LTLD Front & Rear Stabilizer Links
PRL SRS Front & Rear Collar Kit
RV6 Front LCA Spherical Bearings
RV6 Rear Trailing Arm Spherical Bearings
11th Gen Honda Civic TSP FE1: a spicy Si DSC06858_1024x1024
Exterior
OLM Rear Roof Spoiler
Spyder Auto LED Fog Lights
JetsVinyl Yellow Fog Light Tint
JetsVinyl Rear Lower Reflector Tint
27WON Fender + Radiator Shrouds
TSP Locking Security Screws - License Plate
Dress Up Bolts - Ignition Coil Packs (TB)
Dress Up Bolts - Plastic Clip Delete (TB)
Dress Up Bolts - Stage 2 Engine Bay Kit (TB)
Dress Up Bolts - PRL High Volume Intake Kit (TB)
Hybrid Racing Reservoir Cover
JetsVinyl Side Marker Tint
JetsVinyl Ignition Coil Overlays
FL5 Retrofit Grilles & Bezels
Interior
WeatherTech FloorLiners
Escort Max Cam 360C Radar Detector + Dash Cam
FK8 Seat Swap (Driver & Passenger)
11th Gen Honda Civic TSP FE1: a spicy Si DSC09449_1024x1024
11th Gen Honda Civic TSP FE1: a spicy Si Untitled_design_-_2023-11-08T100302.639_2048x2048
11th Gen Honda Civic TSP FE1: a spicy Si 4257908_2048x2048
ThunderPigeon
Long Island
Just need some better brakes, any plans there?
22Si
IL
2022 Civic Si
Looks great! Just waiting here on your new 1.5t downpipe 😙
Savannah@TSP
Savannah@TSP
ValkenDnB
Luis
Civic
So how does tsp stage 1 claim claim 241whp / 286tq but then on tsp stage 1+ they claim stage 1 makes less at 221whp / 251tq and
230whp / 287tq on TSP Stage One+??
What am I missing here?
11th Gen Honda Civic TSP FE1: a spicy Si IMG_0340
11th Gen Honda Civic TSP FE1: a spicy Si IMG_0341
Savannah@TSP
Savannah@TSP
All Dynos and cars test different. The testing done for the Stage 1 tune was completed with a different car and Dyno than the Stage One+ tune. Due to this, they can not be compared. To remedy this, we provide a full data set with a single vehicle for the Stage One+ tune listing:
192whp / 190tq - Factory Calibration
221whp / 251tq - TSP Stage 1 Tune
230whp / 287tq - TSP Stage One+ Tune
The best way to compare the two tunes is to simply use the differences between the factory calibration and each tune.
I hope that helps clear up any confusion!
Savannah@TSP
Savannah@TSP
Thank you for the clarification. Did your stock clutch slip with the stage 1 non +?
There was some slippage in Map 3 during WOT on our otherwise stock Si.
We chose to replace it with the RV6 FK8 Retro Flywheel + Stage 0 clutch kit as it’s rated up to ~400 ft-lbs and only slightly stiffer than OEM.
miles_away
Detroit
'23 Si
Looking forward to hearing more about that BBK if it's meant to be used on a daily driver (has dust boots & seals). Cool to see it's with two-piece rotors too!
DYI01
Dan
It looks like they are gonna try and retrofit FL5/FK8 brakes to the Si.
Savannah@TSP
Savannah@TSP
More details coming soon.
HondaFan777
2023 Civic Type R, 2023 Pilot Elite
Love your build. Did you all have to pull the motor for head studs?
I love this platform as a daily but worry about the head lifting once I start wanting bigger power. I know what this engine is capable of but I want at least power in the safe limits.
