Spoon Air Filter
B16B
2025 Honda Civic Type R
Hi Folks,
I don't plan on modifying my car in any sort of way, but I do like the idea of helping the car breathe a little better by adding in the Spoon air filter. Do you guys think this can cause any sort of warranty issues or concerns?
Thanks
chopsuey34
2025 Civic Si
Hi Folks,
Thanks
Drop-in Spoon filter? No warranty concerns. Plus, you can always put the stock one back in if/when you need to go to the dealership.
However, Spoon filters don't filter as well as stock filters so your engine will be sucking in additional 5-20 micron particles that the stock filter would have filtered out. That's generally not good for an engine in the long term. It's up to you if a few extra hp and noise is worth the risk.
Also, save some $ and get the Sprint filter instead. Sprint makes the filters for Spoon and they're double the price for a re-badge.
Nikw91
Niko West
WPB, FL
2025 CW FL5
The extra turbo/bov sound is worth it! I would bet 99% of people will agree lol
B16B
B16B
Thanks for your feedback.
B16B
B16B
I did watch some YouTube videos. Any other drop in filter recommendation aside from Spoon/Sprint?
Nikw91
Niko West
WPB, FL
2025 CW FL5
PRL just announced on their instagram that they are going to have a sale starting tomorrow. So that’s an option as well for a filter.
11th Gen Honda Civic Spoon Air Filter IMG_3644
blueroadster
Local
Not worth swapping to a different filter IMHO. Engineers that designed the car know their stuff. It is hard to compete with the filtration, flow, and surface area offered by the OEM filter. Another words, save a few bucks and just change the OEM filter more often.
On many platforms, aftermarket intake kits tout increased aesthetics/performance/flow but have other tradeoffs to consider when looking at the filtration media used. Pretty much every aftermarket intake uses a different filter that provides less filtration, increased flow, and a reduction in surface area. That change in filtration media also requires more maintenance as compared to the OEM filter. Aftermarket oiled filters are better at filtration than their dry counterparts but the tradeoff is that they also require more regular cleaning as they clog faster.
Filter media aside, intake housing design is important but that is dependent upon your overall expectations and goals. There are several really good aftermarket intake kits that provide a modified and sealed housing to allow for cool air intake to the filter itself (e.g. improved front intake scoop and top snorkel to the fender). That is something to consider if you intend down the road to upgrade the stock turbo assembly.
For most, the stock intake configuration works and is efficient. When you start modifying the car, one needs to take into consideration many other things. For example, before swapping out the turbo assembly, many other areas need to be beefed up beforehand.
B16B
B16B
You nailed some great points.
B16B
B16B
