SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos are now available to order!
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
I have the revised clutch and will be installing this weekend and will need to break it in before testing the lockout issue. I will install it with the stock slave and line first and see how she does. I want to be able to give feedback with no other variables. I will be running the aluminum flywheel not the steel.
I look forward to your review!
AREA
Chris
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
Thanks! Just want to provide a non biased and detailed review on the clutch! Impressions tips etc. Will also make a how to install as well.
AREA
Chris
Houston, TX
I have the new revised spec stage 3 clutch installed took a day and a half due to a few unexpected issues but it's done. I have the aluminum flywheel and have 0 chatter. Love the pedal only slightly firmer than stock I would say type R feeling.
PS: keeping everything stock like clutch line, clutch master cylinder etc. for testing! Once broken in I will test the lockout issue with the new revision
NoKz
Speed Limit Tester
SoCal
         '18 Si Coupe     '19 Si Sedan   '00 Civic Si    '00 LSV Integra
I get mine installed tomorrow, so I'll be adding info to this post as well.
brianfer.rosa
Brian
18 civic si
Is twostep now selling the revised versions?
AREA
Chris
Houston, TX
NoKz
Speed Limit Tester
SoCal
Got my clutch installed yesterday. Unlike @AREA , I have the Steel SMF and I did the CDV delete. Other than that, we're similar. Stock clutch line, CMC, etc.
First impressions; Clutch Pedal is super stiff but super grabby. Also, the speed in which the revs drop is amazing! The CDV delete hasn't given me any issues and reminds me of my Integra. It's not violent in the least bit. I should have it broken in by the end of the week as I average 68 miles per day round-trip from work. :beer:​
My only real complaint is; Spec Included the WRONG alignment tool for the kit. Luckily my shop had a box of them and was able to locate the correct one.
ebatr24
Oregon
2017 Civic Type R, 2018 Civic Si Coupe
You guys with the lock out issue should consider the modified CTR CMC that Eman sells. Saw an Si owner on Facebook share his review that it resolved him getting locked out on quick shifting. Ordered one the next day from Eman, currently waiting for it to arrive so I can install and test it out for myself. (Running a FX350 myself on stock flywheel)
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
I bought a spare si CMC that’s in my living room. I need to take out the delay valve and install it. I spend about 5 minutes a day trying to take out the C- clip. It’s like my daily devotional.
NoKz
Speed Limit Tester
SoCal
Currently waiting to see how it is once the clutch is broken in to determine if I need it. I believe I have the revised version, so I may not need to.
ebatr24
Oregon
You might be talking about the Slave, that is what has the delay valve that everyone commonly removes. I've seen a few arguments about how it is not recommended, so I have chosen to not do that. Emans CMC is bored out to flow better and is modified which is what he recommends. I figure if he set a record with his delay valve still in the slave, I will keep mine and try out his solution before deciding to remove it.
BoostedDreams
Heisenburg
South East Florida
Yeah sorry I meant the slave master cylinder. Do you have a link to this ?
ebatr24
Oregon
Na I follow him on instagram,(k20z3allmotor) and of course I see his posts on the 10th gen and 10th gen Si group. He has been a pretty trusted Honda guy for a while, building and helping people with the 8th and 9th gens. I think he stated removing the delay valve is harmful to the transmission, he even used someones clutch swap to show how it had affected the trans. Might be worth checking out the CMC before going all out with the slave, I'd say its particularly more important for people running the stock DMF, because aggressive clutches on the stock DMF have a lot of chatter and aggressive engagement.
