PRL Motorsports 1.5T L15B Port Injection Kit
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
As many of you may know, the factory fuel system has been a limiting factor for the 1.5T platform in terms of making big power, especially with ethanol. Though we managed to crack the 400 wheel horsepower a few months back with our GTX2867R GEN2 equipped 2017 Civic Si, the factory fuel system was pushed to the max.
Our solution for this fueling limitation is a proper port injection kit that provides additional fuel flow while reducing intake sludge and carbon buildup.
Kits will include:
  • Intake manifold adapter plate w/ injector ports
  • Fuel rail
  • Stand-offs w/ all hardware needed for install
  • Optional injectors
Users will be responsible for sourcing an injector controller, wiring, fittings, fuel hose, etc.
Our Port Injection Kit was designed around the industry standard Bosch EV14 injector style, which is commonly used by brands like Injector Dynamics, Deatschwerks, Fuel Injector Clinic, Fuel Injector Development, etc, which can be used with most any fueling available.
This kit does NOT eliminate the factory direct injection system.
Due to the thickness of the Port Injection Kit intake manifold adapter plate, a custom or additional coupler hose is needed to connect the charge pipe to the throttle body. We are currently working on a solution for this as well.
Stay tuned for more details as they come! :thumbsup:
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
98 Civic EX with SI Conversion-Sold, 2017 Civic Si Sedan
Kits will include:
  • Fuel rail
Any details yet?
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit PortInjectionKitAssembledFront_zpsiwg9lugx
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit L15PortInjectionAssembledRear_zpsol4bia6
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit PortInjectionKitFrontAngle_zpslcst9dv9
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit PortInjectionKitRearAngle_zps3fbo6jy
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit PortInjectionKitLayOutDisassembled_zpsc4tcripe
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit TopFuelRailFrontView_zpshxn1ncsx
11th Gen Honda Civic PRL Motorsports 1.5T L15B Port Injection Kit TopFuelRailRearViewBung_zpspngrctrq
Now Taking Orders!
Our port injection kit for the 1.5L Turbo L15B Honda Accord / Civic / CR-V & More permits the use of port injectors for additional fueling on high-powered engines by installing between the intake manifold and cylinder head. The port injectors are placed at a specific angle for proper fuel atomization. Please note that this does NOT replace the factory direct injection system.
Kit Includes:
  • Anodized billet 6061 intake manifold adapter plate w/ injector ports
  • Anodized billet 6061 fuel rail w/ (3) ports machined for -8AN ORB female threads & (1) port for 1/8" NPT female threads
  • Anodized stand-offs
  • All stainless hardware required for install
  • 1/8" NPT sealed pipe plug
  • (Optional injectors)
*Users are responsible for sourcing an injector controller, wiring, fittings, fuel hose, etc.
*Designed for use with Radium Engineering Fuel Damper (or similar)
*Due to the thickness of the Port Injection Kit intake manifold adapter plate, a custom or additional coupler hose is needed to connect the charge pipe to the throttle body. We are currently working on a solution for this as well.
*Designed around industry standard Bosch EV14 style injectors (48mm Height), which is commonly used by brands like Injector Dynamics, Deatschwerks, Fuel Injector Clinic, Fuel Injector Development, etc.
