Flushing Brakes
chadwicke619
So, just some thoughts from someone who tracks their CTR and does their own brake work. First, I wouldn't use a pressure bleeder if I were you - not only does it not really make the job any easier, but I find that you tend to use way more brake fluid than is necessary. When you're using something expensive (I use Project Mu G-Four 335 which is pretty pricey), I’d rather not waste it. The stuff I use also changes color as it absorbs water, so you can visually identify when it needs changing. Anyway, just buy yourself a bleeder bottle with a backflow valve and that’s all you need - I pretty much never use my pressure bleeder and just use the little bleeder bottle. The pressure bleeder essentially just saves you from having to push the brake. I’ll do a quick bleed every couple of track days, just to keep my pedal at max firmness, and it takes like 10-20 minutes to do the whole car, including the rebleed on the rears.
S4one
FL5 Type r
Remember when finding a hazardous waste collection can be a PITA. I went to four diff places and they did not accept brake fluid. I ended up giving my fluid to a shop and tipped them.
I almost think paying a shop to do future flushes is more worth it.
Trey
R-00621
Atlanta, GA
Dumb question. My car only has 3500 miles. How can I tell when old fluid has fully flushed out and new fluid is only in lines if both are “clear”? Can I add a coloring of some sort? Missing the ATE blue days. Lol
S4one
FL5 Type r
My car has around the same miles like yours, to be honest, there wasn’t much of a color change and also the reservoir is not completely clear. The clutch uses the same fluid so if you don’t flush that, it will get mixed. I could be wrong…
Trey
R-00621
Atlanta, GA
So I have to bleed the clutch too?!? 🥴
Trey
R-00621
Atlanta, GA
Found the video. Easy enough.
just gotta flush more fluid through. I flushed with 500 miles and was impossible to see so I just did 1.5 litters to make sure. Also common sense to flush more on the rear brakes than on the fronts since they are further apart.
Trey
R-00621
Atlanta, GA
Planned on replacing the brake lines then using autozone dot 4 to bleed the new lines and then flush all that out with Castrol SRF. Don’t want to waste that liquid gold.
That sounds like a lot more work and time and to me time is money. Since srf only comes in 1L you have to buy 2 bottles anyways so Id just do the flush with it since you have 2 L anyways. But yes its def liquid gold, I just get it from fcp euro and just return it each year and have free brake fluid changes for life
Trey
R-00621
Atlanta, GA
Found this dye some have used to detect leaks in their brake lines. I’ll call them tomorrow to see what they say.
https://rekhaoil.com/product/rekhaoil-liquid-petroleum-dyes/
11th Gen Honda Civic Flushing Brakes IMG_2523
BigBird
most of the other bottles are 500 mL. 1 Bottle of SRF is more than enough.
from what I had read to completely flush the system and make sure you don’t have old flush you need more than 1 bottle. Maybe not true and for future bleeds I will just use a bottle only but for the first flush I wanted to make sure the old crappy stuff is gone
