muffin_man
- First Name
- Brian
- Joined
- Feb 12, 2019
- Threads
- 0
- Messages
- 4
- Reaction score
- 3
- Location
- Los Angeles
- Vehicle(s)
- 2012 Mazda2, 2010 Mazdaspeed3
Looks great - emailed!
but but but... connecting to the sub is super easyI assume it’s not quite plug and play once you go for an aftermarket subwoofer because you’ll have to cut the clip off the end of the stock OEM harness to access the wires, correct? If someone made a clip that connected to the OEM harness and other end was standard speaker wire, I’d definitely be all for it.
I wanted more subwoofer bass. Given what was available, which was $399 out of my price range, I decided to make my own 8" subwoofer speaker ring spacer to accommodate a subwoofer that I wanted.
As a result, see the pictures below. Mission accomplished.
Knowing there is others like me, I would like to offer this to others and wanted to gather an interest list so I can make this happen. I'm no engineer or sales/marketing expert. Just want to break even and share this efficient design. Please email me (aparra1191@gmail.com) or reply with your interest here.
My goal is to get these out in a month. I will close the initial order list in two weeks.
Respectfully,
-Anthony
How does that kicker sub sound? Did you change anything else other than adding that ring and connecting it? Nice work man.I couldn't find plugs for the sub or the tweeters. The sub I connected using posi-connectors which are fantastic. I still have the original pigtail.
Truth is I'd never undo any of this work, if I was selling the car it's not worth it to pull and swap everything back and even though it is/will be a collector's car it's not a Buttati Royale so having non-OEM drivers... yeah, not gonna matter.
That's not me - I did not use a ring or Kicker driver, I trimmed a Rockford driver's mounting ear down. It sounds like 5% better than stock? Total waste. I think a cheaper driver might do better and certainly would have been less money down the drain.How does that kicker sub sound? Did you change anything else other than adding that ring and connecting it? Nice work man.
https://www.civicxi.com/forum/threads/icehawks-oem-speaker-upgrade.52608/It would be nice if Honda had given us a separate sub volume level.
I'd like to know the sensitivity, ohms and frequency specs on the factory speaker. There is so much over spec'd junk out there now a days... I need to find an old school JBL, MB Quart or something like that.
Thanks for the link!https://www.civicxi.com/forum/threads/icehawks-oem-speaker-upgrade.52608/
You might find some of that here
