So, I have my setting for the door unlock set that when the driver door opens, all doors unlock. For some reason it's not working. It works when I use the passanger front door. Anyone know what this issue might be? BTW, this is on a FL5.
I don't have your exact problem, but the rear driver side door never unlocks with the keyless entry system. I need to actually press the door unlock buttons to get that one open.
The vehicle settings page seems to indicate that all doors would open so I'm not really sure why it's working this way. The passenger side doors all function as I expect
My FL5 Civic had the same issue with the rear driver door. Turns out it was a faulty lock actuator. Warranty covered it, but it was a hassle getting it diagnosed. Just a heads up in case that saves you some time.
I'm having the same issue on a 2024 US Si. All doors open as expected when using the remote, but if I just walk up to the car and open the driver's door, the other doors do not unlock automatically. I've looked through all the settings and can't figure it out. Please let me know if someone knows the specific setting or issue.
I had the same problem. There are 2 seperate areas that need to be turned on. One is under window/door settings but the other is under the general setting in the key setting. It was the key setting one that had an unlock drivers door only/all doors I did not know about. Problem fixed.
