You pretty much have all your basis covered, donāt forget to bring water for yourself and enjoy your track day.@Club Version, heading for my second track weekend at HMS on March 1-2 (NASA). Canāt wait!
Still planning to run with my OEM pads and tires since they are still in good shape. However, I was thinking about the following upgrades:
- Swap brake fluid to Castrol SRF.
- Adjust alignment. Pull strut alignment pins to max negative camber (to ~ -2).
- Cover wheel weights with insulation tape to avoid them flying away.
- Install splash guards to protect paint
- Remove the metal drain tray underneath the hood vent.
- Install lap timer / camera
Couple of questions:
1) Anything else you might think is Important?
2) For the first 2 points do you know a good shop or dealer in the Miami area to take care of them? For example, what alignment shop do you go regularly or is there one you recommend? Brake fluid, pads and tire alignment will be constant needs, so itāll be cool to have a safe and not so expensive shop to go to that knows the FL5.
Any tips are highly appreciated!
Thanks.
Thanks! Iāll get in touch with Apex.You pretty much have all your basis covered, donāt forget to bring water for yourself and enjoy your track day.
After you remove the alignment pins and push the struts inward, I would recommend you get an alignment at Apex Alignment. Heās very strict with his appointments, so when you call leave a voicemail and he will call you back with availability.
For the brake fluid Iāve always done it myself. Iām not sure if a dealer would swap your fluid to a DOT4 spec. It doesnāt hurt to ask though.
From a quick look they seem to be very similar but I can tell you the MS-C comes with the seat rails for our cars.Do you know by chance the difference between the MS-C and MS-R Full buckets. I have similar waist but I'm 6'3. On every day driving I always sit straight up never really recline. Always been a habit in buckets from past years of drag racing
I seen that. Guess I can call king motor sports and ask the differenceFrom a quick look they seem to be very similar but I can tell you the MS-C comes with the seat reals for our cars.
