Gansan
- First Name
- Glen
- Joined
- Sep 13, 2017
- Threads
- 5
- Messages
- 404
- Reaction score
- 226
- Location
- San Diego, CA
- Vehicle(s)
- 1999 NSX, 2024 Civic Type R
You're right about the definition of riding the clutch, but he's talking about the throwout bearing, which is in between the clutch fork and the diaphragm. If you sit for minutes every day with the clutch pedal depressed waiting for a light, for instance, you are going to wear out your throwout bearing quite a bit faster. It's a dry bearing with only limited lubrication. It's a good reason to sit in neutral at the light or waiting for someone in the parking lot.No, its not "riding" the clutch if the clutch is "fully" depressed. At this point, the clutch is disengaged. However, if you only depress the clutch lightly so its still partial engaged, then you're "riding" the clutch and that will give you a smell like burning brakes. You don't want that. Think of motorcycles. They always have their hand on the clutch lever. It's how you drive a manual. In stop and go, my feet are hovering over the brake, gas and clutch the whole time ready to mange all three while I am in stop and go or slow moving traffic. It's a dance. The only time your foot is not hovering the clutch pedal is if your cruising along. Otherwise, before a turn, in a turn, slow moving traffic your foot shoot hover the clutch pedal. You may need to engage it if conditions change or if you need to "feather" it due changes in speed under slow down or exiting a moving traffic. It's not always press clutch, shift and forget. Your always staying close to the clutch pedal in traffic.
