kin0kin
Kean
Kuala Lumpur, Malaysia
Honda Civic Type-R FL5
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3580
This thread will detail down my FL5 build journey. Below are the list of parts acquired for the build.
Cooling
  1. PWR Street Radiator
  2. Acuity Super Cooler Reverse Flow hose (Not compatible with PRL intake)
  3. PRL Intercooler
  4. PRL Charge pipe
  5. Battle Bee Oil Cooler w/92C thermostat
  6. Battle Bee Transmission Cooler
  7. NTCL Radiator 68C Thermostat
  8. PRL Expanded Coolant Tank
  9. VP Racing Stay Frosty Coolant
Performance & Fueling
  1. PRL HVI Intake
  2. Pracwork CF Intake Manifold
  3. RV6 Catless downpipe
  4. 27Won Kuro Turbo
  5. PRL Titanium Inlet Pipe
  6. DEI Gold Tape
  7. PTP K20C Turbo Blanket - Lava
  8. PTP Downpipe Elbow Blanket - Lava
  9. AWE Touring Exhaust w/Front pipe
  10. Mishimoto PCV Oil Catch Can
  11. Xdi EVO HPFP
  12. Deatschwerks DW300C LPFP
  13. Injector Dynamics F750 Fuel Filter
  14. JSRengine v3 fuel line
  15. Bosch 1400cc Injectors
  16. Aem WMI v3
  17. Hondata Flash Pro
  18. Motul 300V 5W40 Engine Oil
  19. OEM Honda Oil Filter
Transmission
  1. Clutch Masters Cylinder + Hydraulic Release Bearing
  2. Acuity Stage 2 Short Shifter kit
  3. Acuity Red shift boot collar
  4. Acuity ESCO-T6 Satin Black shift knob
  5. Motul Gear 300 75W90 Transmission Fluid
  6. Rigid Clutch Stopper (Not compatible with 2024 Car)
Interior
  1. Zestek OEM Racing hub
  2. Momo Suede Monte Carlo 320mm
  3. Ddpai Z50 Dashcam
  4. Dashcam Battery pack
  5. Toyota Lokatag
  6. Recaro podium M size x 2 (#2)
  7. Recaro ABE side mount (#2)
  8. PCI Bracket & Slider (#2)
  9. Xpel Prime XR Plus 5% Rear
  10. Xpel Prime XR Plus 15% Front
  11. 3D Mat Glory Carpets
Braking
  1. Endless Mono 6 BBK
  2. Endless MX 72 Front Pads
  3. Endless CC-RG Front Pads
  4. Girodisc 2 Piece Floating 305mm Discs
  5. Endless MX 72 Rear Pads
Handling
  1. HKS Hypermax R Coilover
  2. Stanceparts Aircup front lifter
  3. Whiteline Rear Sway Bar
  4. Whiteline adjustable rear sway bar link
  5. Whiteline adjustable front sway bar link
  6. Whiteline rear lower camber arm (camber)
  7. SPC forged steel rear control arm (toe)
  8. Power flex 95 anti lift kit
  9. Power flex 95 front LCA bush
  10. PRL Motor Mount
  11. PRL Front Strut Tower Bar
  12. PRL SRS Collar Kit (Front and Back)
  13. Spoon Stiff Plate (Buy Cusco Instead)
  14. Bridgestone Re71rs 295/30/18
  15. Bridgestone Re71rs 265/35/18
  16. Custom Forged 18 10.5jj +47
  17. Custom Forged 18 9.5jj +38
Rattle Fix
1. Immobilizer (#5)​
2. Headunit/Dashboard (#23)​
Battlebee oil coolers are made in china. You can grab them on AliExpress. I also ordered the transmission cooler which sits on the adjacent side of the oil cooler. There are a few thermostat options, I went with the 92c thermostat after much consideration. This can be changed later on if I need the oil to be cooled earlier
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2392
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2393
Thermostat is built-in here.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2396
Impressive. Doesn’t look any worse than Hel but it’s a Hel-lot cheaper šŸ˜‚
kin0kin
kin0kin
Kean
Dashcam Installation
I’ve been using DDPAI dashcams since their initial launch. They provide high-quality sensors and excellent post-processing. I prefer to install them myself, as many shops and technicians tend to rush the job, often skipping proper preparation and risking scratches.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1241
To remove the A-pillar cover easily, start by taking off part of the window molding. Then, place your fingers in the groove and pull the A-pillar cover in the opposite direction.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1236
Even with the service manual, removing the top clip was difficult because I couldn’t access the upper inner clip while the A-pillar cover was still attached.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 4828D369-0A92-49D1-9EA0-DB358A5582FF
Apparently, you simply need to slide the A-pillar cover out and upward after pulling it. Take care not to damage your headliner during this process, as it gets quite close.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1237
detach the speaker cable and you are done
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1248
the bottom trim is held by clips. Pull towards the seat to remove it
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1254
There are two screws that must be removed before you can take off the side panel on the driver’s side. I hope no one attempts to pull this panel off without realizing this, as most cars typically don’t have screws securing the side panel. Interestingly, the passenger side panel doesn’t have any screws at all.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1252
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1902
Fuse diagram can be found under the steering column
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1955
This has been the most difficult part of the installation. It took me a while to figure it out because I didn’t want to lower the headliner too much and risk damaging the edges. Apparently, there’s a hole next to the grommet hole where you need to loop the wire puller in and out of the headliner. Bending the wire puller into a U shape will help it come out from the back.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1793
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1956
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1957
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1960
It was also quite challenging to push the wire puller into the hole. I had to wiggle the harness inside while inserting the puller. My rear dashcam wire is thick, so I couldn’t tuck it under the windscreen edges. Instead, I had to loop it back and pull it out through the rear wiper washer hole.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1961
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1963
Connected the rear cam. Wrapped it up with felt tape and pulled back the excess wire.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1964
Taped the excess up and it’s good as oem
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3714
I wanted to cut out these grills to route two wires out to the dashcam but it seems like I could just stretch them and pass through the cables.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3716
I managed to get the wires through without breaking anything.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3720
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3724
OEM+ Fitment :)
kin0kin
kin0kin
Kean
Stripping off the interior
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1942
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1913
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1914
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1916
I’ve seen several videos where people use prying tools on the soft-touch dashboard and AC vent to remove them, risking scratches and damage. However, you can easily pop them out without any damage by first removing the side panel. Then, use your hand to push the AC vent out from behind. Gently pull the trim from both the top and bottom simultaneously towards the other end, and it will come out smoothly without risk of damage.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1918
Always a good idea to tape this up. It’s almost a guarantee hit when removing the AC trim
Active sound module
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1929
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1927
The fake exhaust note module is attached to the glovebox assembly. One wire and two clips are what you need to remove.
Stage 2 Acuity Short Shifter
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1984
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1971
Somehow I missed out the solid shifter bushing. Gotta buy it tomorrow and complete the upgrade
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1977
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1981
The most effective way to remove this is by using a sharp pick tool to tap on each locking leaf. Avoid using a flathead screwdriver, as it can slip and scratch the shifter frame. Gently tap each leaf, and it will eventually come loose.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1982
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1985
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2076
managed to get the final missing piece
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2172
I finished installing the stage 2 kit today, but I’ll hold off on the spherical bushing until I work on the engine bay. The shift from 4th to 5th feels a bit tight and difficult. It’s not as short and crisp as the CAE shifter I remember from a GR Yaris I tested. I still have the Hybrid Racing detent springs and Aquity spherical bushings left to install.
Acuity Esco + Collar
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 0172D95A-EC47-43DB-86DB-6D4A6F3F1462
I’m not a big fan of this setup. First of all the circumference of the collar is too narrow. It’s impossible to not have any wrinkles when zip tying the boot down. I have hyper-hidrosis. My hands are permanently sweating. Metal/Delrin knobs slip off my hand when shifting. Also I kinda like low shifter and I do taichi/kungfu shifts. These will have to go. I’ve ordered the red Honda Access leather knob. If anybody wants these drop me a dm.
Hybrid Racing Detent Springs + Acuity Spherical Bushings
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3994
Didn't grab many pics here. Installation is cumbersome. I did it the ā€œproperā€ way by first releasing the retention clips on the shifter cables before prying out the bushings. I’ve only shifted with the car stationary and didn’t feel a whole lot diff with the spherical bushing. OTOH changing spherical bushing on the GRC made a huge difference. The detent springs definitely gave more confident that the shifter will default into center position. You can’t possible shift wrongly with these mods.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4001
kin0kin
kin0kin
Kean
TSP Fender Rock Guard Installation
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1774
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1775
Remove the screws. Pop the clips. I broke all of them. I’ve removed a lot of clips under the car and none broke but these clips are just especially fragile. Had some spare lying around so I used those. Gonna order some new original clips 🌚
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2092
Got myself some replacement clips today. May as well grab some filters!
AWE Touring Exhaust
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2045
I have not listened to them in person but I’ve heard them in the B58 M340i. Very nice sounding exhaust and definitely no drone on the Touring edition. Got myself the chrome tips and a customer ordered a set of black tips.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3759
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3758
The other day I installed a customer/friend’s exhaust. The whole muffler was crooked in relation to the outlet section. It’s really blatant.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4127
Here’s mine in comparison. At least this set is relatively leveled. When it comes to welding quality, this is not the best but I have seen one particular brand that is far worse. But let’s not mention it.
With regards to the sound. It sounded really good with no drone in the cabin when paired with stock downpipe. I’m running Catless RV6. I think it’s going to be really loud. However it’s never going to be notoriously loud like Tomei/RSE.
I particularly like AWE’s tip sizes and finishing.
Hondata Time
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1990
Ecu held by two 10mm. Remove that and unclip the harness. Remove the four 10mm to release it from the metal casing. My unlocker didn’t need me to remove it out of the plastic housing
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 562e8176-6335-445d-a448-2e383f7e987d
Jailbreak is done today.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2416
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2418
Wouldn’t wanna drop this in the engine bay.
HKS Hipermax R + Stanceparts Aircup
If you ever decide to get a pair of air cups for Hipermax, you’d need the 45mm cups. Unfortunately they are out of stock at the moment and I’m still waiting for my cups to be shipped. I can’t foresee driving the car anywhere with a lowered 18ā€ setup
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2140
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2800
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3408
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3411
Collected the Hipermax R with Canceller kit today. Unfortunately the air cups are still not available.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4118
The front is installed today. I’m disappointed to see that the shock body isn’t adjustable. Some R’s in other cars have adjustable casing length. I’ll remove the springs and do a bump stop check. I really don’t wanna destroy my fenders/tires.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4323
Here’s a view on how to adjustment knob gets routed to the bottom of the wheel arch.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4322
Taped up the contact point to prevent tapping noise/rattle
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_4324
Another strange thing that I realized is that the testing data and optimal height published by HKS doesn’t match the stock height that I measured myself.
SPC Forged Rear Camber Arm
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_8910
Opted for the forged iron arms over aluminum ones. I am running full set Whiteline suspension kit but the Whiteline arm just looks like a serious overkill and it’s quite a bit heavier than SPC’s offering.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 8804cde6-5d4e-4ac0-866f-1857a347a72
Unfortunately these do not come with the sensor brackets. Gotta have to order the aluminum ones.
Throttle Pedal Offset Spacer
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_8829
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_8830
Got these from ā€œTaobao - China Amazonā€. Haven’t installed them but seems to solidly made.
Custom Forged Rims
I scanned and replicated my TE37 Saga S Plus face 4 and face 5 that I had on my Supra. I opted for a 10.5 +47 upfront and a 9.5 +38 on the rear. 9.5 +45 is common but after seeing both +45 and +38 in person, it was clear to me that a 265 9.5 +38 on a lowered stance with the extra camber looked much more flushed than a +45. Rims will be done in a couple more days.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 6cd8d50a1d597a4679e435762deb0cf6
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 9a794bd23941aa6bb52ce15b570d92c4
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build 53d4110ac8e492a70e54effa499bac5a
Rims are done. Will be wrapping them in Bridgestone RE71RS 295 front and 265 rear. I’d like to go thicker profile once I’m done with these.
27Won Kuro Turbo
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2263
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_0876
I’m aiming for 400hp+ of usable power on the street and on the track. Much thanks to Corey @Two Step Performance for the advice. Hope the turbo delivers what I need. To put down these power I opted for 295 RE71RS. A very common tire size and choice for those who track their Type R here.
Pracworks CF Intake Manifold
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_2828
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build ae8f823d-3ad0-4315-a919-b16c81a0df11
Received the intake manifold today. Rather impressive ā€œlocallyā€ made product to be honest. Haven’t really taken it out of the box yet. Pictures taken by factory.
kin0kin
kin0kin
Kean
Reassembly
Rattle Fix #1
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1952
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_1953
I’m not sure what this module is but this is the cause of rattle under the dashboard around the hvac controller. It’s held by a push pin. You need to put your hand above and behind the controller and pinch it then lift up to remove it. Pad it with some foam tape before reinstalling to eliminate any play
Update: It seems this is an immobilizer. Without this connected the car would crank but it would never start
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3031
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3032
Taped up the plate so there’s absolutely no play from this module.
A Pillar Cover
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3698
Takes only a couple seconds to prevent possible scratches.
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3697
this was challenging to remove earlier on. Clip it all the way back before pushing the cover back into place.
There’s nothing much to talk about reassembling the cover. Remove the molding, align the clips to the holes, and just clip it back.
Rear view Mirror Covers
11th Gen Honda Civic 2024 REVWORX FL5 Type R Build IMG_3696
There were rattles coming from this area. I simply padded the edge with 3M foam tape before reinstalling this.
Acropora
J
CTR FL5
Nice list of mods and great picture tutorial of all the work you’ve done!
Zero7
Avtar
UK
FK8
serious list of parts there…
kin0kin
kin0kin
Kean
Great build $$$$
Im still debating if i should get mhi drop in or rv660 or kuro.
I thought mhi has the best low range and mid range which is what we need on the track. (Not drag racing)
Initially I wanted the rv6 660as but the chart just didn’t seem very right. Let me try this kuro and report back. I’m expecting some good low end results with the pracworks intake manifold in this build.
Oh btw the only track I have here has a couple of long corners and a long straight. 400hp and above needed to hit certain timing for sure.
Did you order the Kuro+ ?
Excited to see this one come together! A very nice build and well documented too! šŸŽ
arcticdc5
Kevin
Virginia
RSX-S, 6MT Tacoma
Wow - this is one attention to detail build and not just a bolt on catalog parts car!
TchnoZ33
Zaid
Indiana
Recaro Podiums
Podiums arrived. I had in mind that I ordered red alcantara but received them in black. Probably have to order some red pads later on. @VividRacing
AWE Touring Exhaust
Hondata Time
Custom Forged Rims
27Won Kuro Turbo
You made your own wheels?!
