yeaitsahonda
David
Virginia
2023 Boost Blue Type R
This won’t be much of a build thread as my plan is to keep the car mostly stock. Mainly wanted to start a thread to keep track of any little things I do to it and keep some notes about the car.
Here it is the night I picked it up from the dealer.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 596C5B76-D251-414F-B090-93EDF18F9E70
Took the car to a cars and coffee event the first Saturday I owned it. Instantly had the attention of a lot of people. Was very cool to see how many people liked the car. Other than that so far have just been cruising around in it getting some easy break in miles.
After a month of ownership I finally broke down and bought a car washing starter kit from Chemical Guys. Foam cannon is fun but I still hate washing cars. Here it is during and after the wash.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal CB8EBE25-E374-410E-B263-637AB7E7868C
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 81FDF135-96C7-414D-AC08-3E4DE34D7C81
Some small work to get done before a track day weekend coming up in early March. Going to change the oil, swap out the front pads for a set of Performance Friction 08 pads, flush the brake fluid with Castrol SRF, remove the front strut pins for more negative camber, and then align it. Then just hope and pray that the weather is warm enough in March to drive on the factory Michelins. Excited to see how the car performs on track.
rob495
Rob
CT
Wow! Trying to decide between CW and BB right now. your car is swaying me. Post more pics when you get the chance!
yeaitsahonda
yeaitsahonda
David
Virginia
Can't go wrong with either color. Although I'm a big fan of the blue. Planning to have it on the alignment rack tonight after work. Will snap some more pics of it then.
yeaitsahonda
yeaitsahonda
David
Virginia
Got the alignment done tonight. Removing the pins for the front struts was pretty easy. Took camber readings before and after. Removing the pins gained -0.3 degrees of camber. Not a ton and unlikely to noticeably change how it handles but hopefully it will help with tire wear on track. Note- it did change the front toe a lot so if you plan on doing this you will need to check the toe.
Here she is on the alignment rack
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 5673293E-C265-4F51-99C0-DC94D5475868
Alignment numbers before doing any work.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 9503D6FA-F857-47BD-9AB9-0991DD04B2DC
Getting the strut pins out. Put some painters tape down to keep from scratching the paint with the washers.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal F61F7B3E-5898-452D-946C-7027B4EE06E4
Here is a pic showing how much room there is to move the strut. I’ll need to get some touch up paint to cover where the nuts were.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 868D8A3A-2A62-4B6C-8F20-10E8FA52A805
Alignment numbers after moving the front struts.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal D5C86DFE-B320-41C3-A780-571B4AEE6B5D
And finally the completed alignment numbers. (Caster is now green because I changed the specs at the end to make it green. Didn’t actually change anything on the car)
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal B3D95E7B-0CE9-4ED9-8DC6-3B87B0F1FC31
Shameless parking lot pic at dinner afterwards
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 6ABC5C1E-D444-4D32-8145-DD826477ED70
yeaitsahonda
yeaitsahonda
David
Virginia
When we started calling about them we put deposits on a red one and then the blue one. It’s “technically” my wife’s car and she said she wanted whichever came in first. So happy the blue came in first haha.
CTRifecta
MA
I have a deposit on a boost blue and sometimes wish I could have CW, but then see pics of the blue and it looks so good ...
yeaitsahonda
yeaitsahonda
David
Virginia
Championship White is iconic but zero chance I'd be able to keep it clean. Also, my Miata was blue with black accents so it seemed fitting to get the Boost Blue.
machimself
Michael
CW was my first choice and SGP second. Blue wasn't really on my radar but so glad I got it. The most striking and also most fun color of the bunch without a doubt.
yeaitsahonda
yeaitsahonda
David
Virginia
Solid weekend of playing with the car. Nice weather yesterday so got to take it out for a blast. Then to the shop to get some track day prep done. Started with washing the wheels. Then came back today to ceramic coat the wheels and the Brembos. Got the front pads swapped out and the brake fluid flushed. 3 weekends until the track day where I’ll really get to see what this car is all about.
Dirty wheels
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal E4D99771-741B-4CCC-B221-B4380BCDE98C
Cleaned and ceramic coated wheels and calipers
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal F54DB42E-47D5-42F8-A2E6-F5D7FA10F462
Lastly getting the brake work done
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 12205868-7826-46F0-A121-942D42160C1E
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal BED35636-3697-4AC7-8F3C-6A9C06348641
Beautiful color. I wish the Type S would offer a decent blue. Only their PMC Laguna Beach Blue is worthwhile 😒
yeaitsahonda
yeaitsahonda
David
Virginia
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 4E71E870-1CDA-468F-8BA7-BA0459360EB7
First track day in the Type R is done. Holy shit this car is fun. I think I’d have to agree with the reviews I saw before buying it that unless you’re on a perfectly smooth track the +R mode is too stiff. Ran my best lap time in Individual mode but without being able to turn VSA off there is still some more time to be had. The VSA kept it from rotating in the slow speed turns and really forced me to slow up corner entry.
I did have some braking issues. The PFC pads that I put on it were causing a pretty bad vibration so I went back to the OEM pads. With both sets of pads I keep getting the yellow Brake System warning light coming on. Unsure what’s causing that but it seems to stop fine.
I was able to get the LogR to work and it’s very cool. Seeing lap times as you start cross finish is nice and the extra data available on the app later is fun to study.
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 35634A99-6A2D-4B35-8721-CA400F820323
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 556B6410-0C9A-4842-99BF-08468FC1835A
11th Gen Honda Civic Yeaitsahonda’s FL5 Ownership Journal 2A389945-00DB-4CBB-860E-5C5184F659E8
Tickle
Very nice! I haven't been up Summit Point in some time and always as a spectator.
