One of the first items I wanted to address on the FL5 is the less than ideal wheel offset. I didn't want to turn to aftermarket wheels since I'm a huge fan of the 19-Inch Matte-Black Alloy OEM wheels. I decided the best path forward is to explore wheel spacers to move the wheels and tires outwards so they are more flush with the fender. The question that often arises is, "What size wheel spacer should I run to achieve the desired stance?" The answer is: It's a matter of personal preference. This thread will serve as a reference to help make that decision a little easier.
Submit your entries using the following format:
1. Year and model:
(e.g.: 2023 Civic Type R)
2. Wheels/offset:
Front: (e.g.: 19x9.5 OEM Matte-Black Alloy, ET +60)
Rear: (e.g.: 19x9.5 OEM Matte-Black Alloy, ET +60)
3. Tire size:
Front: (e.g.: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL)
Rear: (e.g.: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL)
4. Suspension:
(e.g.: Stock, Spoon Sports Progressive Spring, Eibach Pro-Kit Performance Springs, HKS Hipermax R Coilover Kit, Ohlins Road & Track Coilover Kit)
5. Wheel Spacer Brand and Size:
Front: (e.g.: Perrin 25 mm, H&R TRAK+ 15mm)
Rear: (e.g.: Perrin 25 mm, H&R TRAK+ 25mm)
6. Clearance (i.e., Does it rub? If so, when?)
Front: (e.g.: Rubs backing out of an incline)
Rear: (e.g.: N/A)
7. Wheel Studs
Front: (e.g.: Stock)
Rear: (e.g.: Stock)
8. Insert photos
I will get us started.
1. Year and Model:
2. Wheels and Offset:
Front: 19x9.5 OEM Matte-Black Alloy, ET +60
Rear: 19x9.5 OEM Matte-Black Alloy, ET +60
3. Tire Brand and Size:
Front: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
Rear: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
4. Suspension:
Stock
5. Wheel Spacer Brand, Type, and Size:
Front: BONOSS Forged Lightweight Plus AL6061-T6 15mm
Rear: BONOSS Forged Lightweight Plus AL6061-T6 18mm
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0021
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0019
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0016
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0015
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0008
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0010
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG-20230428-WA0018
POPNTEC
CW FL5 CTR
Are you guys running stock wheel studs with your spacers?
CTRPR
JC
www.youtube.com
FL5 M3CS 4Runner
1. Year and Model:
4. Suspension:
Stock
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
Thanks man!!! Had not bought any spacers si ce non were Fl5 specific, but since you used the FK8 (Yes I am aware that bore and bolt pattern is the same) ones with no problem I went ahead and ordered the same just now. 15mm all around jeje
CTRPR
JC
www.youtube.com
FL5 M3CS 4Runner
How much time did the Bonoss people took to ship the spacers and how long did it take for them to come. Just noticed they are based in china lol.
The timeline I was provided by them when I requested is as follows:
"We will need 8-10 days to make the custom spacer , 4-7 days shipping time , total 12-17 days ."
I ordered on March 24 and received it on April 11, so a little past the quoted timeline. It's worth mentioning, I ordered custom spacers for the rears so you likely will not have to wait as long. It appears you are also in PR so not sure how that may or may not impact the timeline.
CTRPR
JC
www.youtube.com
FL5 M3CS 4Runner
Thanks man!
Oneday
Florencio
Massachusetts
2018 Rallye Red CTR
25mm all around. Oem wheels/tires.
H&R Sport .8 inch all around.
No rubbing under any circumstances so far.
Love the stance on the stock wheels and tires!🙌🏽 Have you noticed any negative affects with the quality of the ride, such as noticeable understeer, the car not holding a line through turns, or sloppy turn in? I’m definitely thinking about doing the same thing to my Boosted Blue fl5, so I was just curious about your before versus after experience?
CTRPR
JC
www.youtube.com
FL5 M3CS 4Runner
1. Year and Model:
4. Suspension:
Stock
Rear: BONOSS Forged Lightweight Plus AL6061-T6 15mm
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread 2E7E64D2-9F33-4EE5-92C8-81B0D9A1B6A8
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread BEB6AE9D-192B-4C86-BAD5-4AABCF324E0D
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread EDBC4D40-8B50-460D-A3E2-38572A336D53
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread C6EE4453-F5FC-4247-B4FC-60EA953B1D54
@CTRPR Looks good! How do you like it? Any other thoughts?
