Sporky McGeuschky
- Thread starter
- #16
Here I Pre-Bent the Rally Mud Flap a bit for ease of alignment to Screw holes.
There are now just Four Button Head Screws with RokBlokz Washers left to install.
Now, attach the Top Button Head Screw with Washer by hand.
Next, attach the Underneath Button Head Screw and Washer.
Attach the other Two Button Head Screws with Washers, and leave the Screws loose enough to adjust Rally Mud Flap Outpoke Width.
Rear Rally Mud Flap Pulled Out Wide.
Rear Rally Mud Flap Tucked In Tight. This is the Install method I chose.
All Four Button Head Screws with Washers attached, and Rear Rally Mud Flap Tucked In Tight.
Tighten all the Screws, being careful not to strip any Screw holes.
Rear Right Mud Flap Installed.
During the Install, make sure to keep all of the OEM factory Hardware organized, keeping the Front Hardware separate from the Rear Hardware.
I reused the RokBlokz zip seal bags to collect the OEM Hardware.
Now Install the other side and the whole RokBlokz Rally Mud Flaps Install is complete.
Double check for any loose or missing Hardware. Upon collecting all the OEM Hardware, I noticed there was One RokBlokz Punch Plug sitting out by itself. Turns out it was a spare.
I checked to confirm I had a spare Punch Plug by going back and looking at a Hardware photo. Sure enough, there were Five RokBlokz Punch Plugs amongst all of the Front Hardware.
Congratulations! If you made it this far, your RokBlokz Rally Mud Flaps Install is Fully Complete!
Enjoy!
Enjoy!
