blueroadster
- Joined
- Apr 19, 2024
- Threads
- 16
- Messages
- 242
- Reaction score
- 252
- Location
- Mid-Atlantic Region
- Vehicle(s)
- 2024 Civic Type R, 2020 F-150, 1964 Impala SS
- Thread starter
- #1
This post compares various FL5 intercooler offerings. Note that volume is calculated using the core width, height, and depth measurements. Actual internal volume will be less.
Please respond with any additions and/or corrections. Here is the list ordered based on weight (low to high):
- OEM:
- Type: Square T&F
- Fins: 11
- Tubes: 10
- End Tanks: Resin
- Stock IC Elbows: Retained
- Core Size: 639 x 158 x 64 (25.16"W x 6.22"H x 2.52"D)
- Volume: 393.6 cubic inches (6.45L)
- Surface Area: 100,962 mm squared (156.50" squared)
- Modifications: None
- Weight: 6.9 lbs.
- PWR:
- Type: Hybrid B&P
- Fins: 13
- Tubes: 12
- End Tanks: Machined billet aluminum
- Core Size: 700 x 181 x 87 (27.56"W x 7.13"H x 3.43"D)
- Volume = 672.66 cubic inches (11.02L)
- Surface Area: 126,700 mm squared (186.62" squared)
- Weight: ~11 lbs.
- J's Racing:
- Type: T&F
- Fins: 11
- Tubes: 10
- End Tanks: Sheet metal
- Core Size: 700 x 172 x 100 (27.56"W x 6.77"H x 3.94"D)
- Volume: 735.36 cubic inches (12.05L)
- Surface Area: 120,400 mm squared (186.58" squared)
- Modifications: Minor trim to move air temp sensor higher on the bracket
- Weight: 13 lbs.
- HKS:
- Type: T&F
- Fins: 10
- Tubes: 9
- End Tanks: Cast aluminum
- Core Size: 695 x 178 x 100 (27.36"W x 7.01"H x 3.94"D)
- Volume: 755.88 cubic inches (12.39L)
- Surface Area: 123,710 mm squared (191.79" squared)
- Weight: 15.65 lbs.
- RV6 (yet to be released):
- Type: Square extrusion T&F
- Fins: 15
- Tubes: 14
- Stock IC Elbows: ???
- Core Size: 695.3 x 177.8 x 101.6 (27.37"W x 7.00"H x 4.00"D)
- Volume: 766.88 cubic inches (12.56L)
- Surface Area: 123,624 mm squared (191.59" squared)
- Modifications: ???
- Weight: 16.4 lbs.
- Wagner:
- Type: Square T&F
- Fins: 25
- Tubes: 24
- Stock IC Elbows: Replaced with silicone elbows
- Core Size: 580 x 400 x 70 (22.83"W x 15.75"H x 2.76"D)
- Volume: 991.86 cubic inches (16.25L)
- Surface Area: 232,000 mm squared (359.57" squared)
- Weight: 21 lbs.
- PRL:
- Type: B&P
- Fins: 9
- Tubes: 8
- Core Size: 720 x 184 x 109 (28.35"W x 7.24"H x 4.29"D)
- Volume: 880 cubic inches (14.42L)
- Surface Area: 132,480 mm squared (205.25" squared)
- Modifications: Minor trim to move air temp sensor higher on the stock bracket
- Weight: 22.6 lbs.
- Airtec:
- Type: B&P
- Fins: 11
- Tubes: 10
- Core Size: 700 x 190 x 130 (27.56"W x 7.48"H x 5.12"D)
- Volume: 1,055.10 cubic inches (17.29L)
- Surface Area: 133,000 mm squared (206.15" squared)
- Weight: 23 lbs.
- MDR:
- Type: B&P
- Fins: 9
- Tubes: 8
- Core Size: 711.2 x 178.31 x 139.7 (28.00"W x 7.02"H x 5.50"D)
- Volume: 1,081.09 cubic inches (17.72L)
- Surface Area: 126,814 mm squared (195.56" squared)
- Modifications: Removal of air temp sensor bracket and relocation of the sensor to a bracket on the top side of the intercooler
- Weight: 29.5 lbs.
- Spoon (yet to be released but likely inflated price for the label): ???
