Boomba Racing
Civic X Vendor
- Joined
- Nov 30, 2016
- Threads
- 81
- Messages
- 603
- Reaction score
- 149
- Location
- Wood Dale, IL
- Website
- www.boombaracing.com
- Vehicle(s)
- 2017 Civic Sport, 2018 Civic Type-R, 2010 Civic SI, 2015 Civic SI,
- Thread starter
- #1
Boomba Racing is very excited to bring you our Blow Off Valve for the Tenth Generation Civic!
Available here: http://www.boombaracing.com/2016-honda-civic-blow-off-valve-1-5-turbo/
Installation guide: http://www.boombaracing.com/content/CIVIC X - BLOW OFF VALVE MANUAL.pdf
No aftermarket tuning required. Will work on stock tune or aftermarket tunes. This piece does not throw any check engine lights, does not cause any turbo lag, and does not make the vehicle stutter between shifts.
Replace your factory BPV which is made of cheap rubber and plastic and known to rip and leak boost. This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 100psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
Installation is simple (direct replacement to stock) and all necessary hardware is included.
Available in your choice of color: Black, Blue, Red, or Pure Aluminum
