twostep/launch control
tc726
tyler
florida
11th generation honda civic si
is there a way to change the interval in which the rpm’s bounce off the rev limiter when i select an rpm with my tsp tune for launch control? i have a ktuner
Johaw
2023 Civic si
Launch Control:
On the fly adjustable launch limit allows you to adjust your launch limit RPM on the fly via cruise control switches.
Cruise Control must be fully off and not active on the dash.
To enter the adjustment press the clutch in fully.
Click the cancel button for a short press.
The tachometer should show your current RPM for launching.
Make adjustments on the fly in 100 RPM increments by clicking Resume or Set buttons to increase or decrease.
As this is on the fly, release the clutch pedal or click cancel again for a short press to go back to normal tachometer operation.
tc726
tyler
florida
i know how to use it i just wanted to see if i can make it bounce off limiter faster
