Multiple Sensor Errors after alignment
Jaymes
South Florida
2024 Honda Civic Type R
I work at a shop and had a tech do an alignment, we were attempting to relearn the SAS, as my steering was still a touch off, but now the cluster is lit up like a christmas tree. Car drives perfectly fine, but all driver aids have an error, and the car is stuck in sport mode. I tried disconnecting the battery for a bit but that didnt clear it either.
Looking to see if there is anything I can do before I get back to work tomorrow.
Thanks
Motpeds
Pedro
Chicago
FL5 - CW
Does the cars dampening feel a bit softer? If so, take a look at the ads unit. It might’ve gotten unplugged. When this happens the car can only access sport mode. Might be your problem!
Jaymes
South Florida
It feels firmer due to it being in sport mode, but nothing was unplugged. Just did an alignment and plugged an autel scanner in to reset the sas to center.
Tougefl5
Check the ABS harness that plugs into the bottom of the strut. Or bring it by a honda shop and have a technician run a diagnostic test.
Jaymes
South Florida
Ill be running a diag on it tomorrow at work, was just seeing if there was something I could reset before hand.
anri
Jesse
SoCal
2024 Civic Sport , 2018 Civic Si
Have the lights gone away?
Jaymes
South Florida
Yes, we did a full reset of sensors at the shop. The techs are thinking it just was because of a failed SAS calibration.
