First track day, now tires are “noisy”?!?
Trey
R-00621
Atlanta, GA
Had a blast on a local track yesterday, first time in this car. Three 20min sessions. Tires definitely got warm but they look normal after a track day. Driving home after and also today I noticed the OEM tires are noticeably louder/ road noise. I have around 3800 miles. Is the added noise normal? Just seems odd.
J1Avs
James
Seattle, WA
www.instagram.com
You probably have a ton of OPR (other people's rubber) on your tires -- standard stuff, you can scrape it off with a heat gun and scraper/chisel if you want.
Trey
Trey
R-00621
Atlanta, GA
I checked, no boogers.
Noize
Under the radar
Hey Trey, it’s Seth. That’s just feathering because of stock camber. It’s a sign you’re doing good work out there!
Get you a cheap second set of wheels and 200TWs to mount up for next time.
Trey
Trey
R-00621
Atlanta, GA
Hey buddy! Good to hear. Car is on stock suspension. Yeah hoping to get some 18’s at some point.
I had a lot of this. Turning off traction control and inducing a bit of wheelspin took care of it pretty quickly. :)
Bugzy2
Stephen
Dubai, U.A.E.
2023 Honda Civic Type R, 2009 BMW M3
It will go away after a while.
