Clutch pedal noise
KeglerKing
Tony
Earth
2023 Honda Civic Sport Touring Hatchback 6MT
Hello: I have a 2023 Honda Civic Sport Touring Hatchback 6MT with 18k miles. Just bought it back in March 2024. As of a couple of days ago, when I release the clutch pedal, it's giving me a little single (clicking?) sound right at the top of the pedal travel. You know that sound it would make if you were to sideways slide your foot off the pedal while it's not quite fully released and still traveling upward? It's kind of like that. It almost feels like it's just slightly loose/wiggly, if that makes sense. By the way, when I release the clutch pedal, I make sure to keep my foot centered on it all the way through the full disengagement. What do you think it could be? Thanks in advance.
Might be the pedal switch. You might be able to push the switch with a screw driver to see if the noise is the same.
However, I had an Acura TL 6MT that started clicking around 48k miles. The dealer replaced the clutch master cylinder under warranty due to a broken spring. Clutch still felt okay-ish, but it was clicking on the pedal down stroke and up stroke.
